Guest viewing limit reached
S
smartspark
Here we go again I hear someone groan :rolleyes:
The question I have is, can I issue a minor works cert if Im not registered with eca or niceic? Im full scope part P, and have modified the circuit in a office block communal passage and ladies toilet.
I know that you have to issue a minor works cert with every circuit modification in a domestic premises, Is this the same in a commercial property?
Thanks Bugsy, so I can take on more commercial work and issue minor works certs even if I'm not 2391 yet?
as long as you're competent to test your work, there is no legal requirement to have 2391. however, if you are ever called into a court of law, having 2391 helps to prove your competence as regards testing etc.
What a mad world we live in, you need more quals to do house bashing these days, how did that happen???
it happened all due to some politicians wife getting a shock. instead of making sure of the job. he instigated part pee.
No-one's wife. A female MPs daughter was electrocuted. It's not entirely clear that this instigated Part P of the Building Regulations in England and Wales however, as I believe they were already in the process of being introduced. As I don't live in England or Wales I don't purport to be an expert however!
I believe it was a daughter of a politician that got killed after some shoddy work in her kitchen, from a fault on the washing machine to the kitchen sink, made a circuit and kaput.
i stand corrected. obviously i was only told a part of the story. never mind, though, we've got part p now so everbody in the country ( apart from scotlan and horses) is safe from electrocution.
MWC on commercial work
smartspark,
telectrix,
