the way i wire digital and sky so you can view it in any room you have a point is......
take a ct100 cable from a digital ariel down to your sky+ box and connect into the rf1 output.
then take another ct100 cable from the rf2 out on your sky box to a booster box, where ever you think is best to put it (loft cupboard etc)
then out from the booster in ct100 again to which ever points in the house you want, then from any room with a point you can watch sky or digital tv :)
one point to mention, where ever you decide to mount the booster you will need a socket, so if you plan to install the booster in the loft dont forget the socket in the loft
thats the way i allways do it hope that helps
If you want Sky+ do you not need two cables to the reciever from the quad LNB and then a 3rd CT100 as the return to the distribution amp or similar so it will pass to other TVs ????
I know guys who run a 4th CT100 also for DVD/video to other TVs. Just a thought.
Possible on 2 cables from hub to TV and 2 from dish to HUB but 3-4 are better.
are you qualified , can you test and certify your work or are you getting building control to do it, cos all of this sounds iffy, a sparks wouldnt be asking such questions?
wasnt the original string about wiring up his power cicuits?:confused: or have i had one too many..:eek:
