B
BillyTheSparks
@ Hawk81
No worries buddy.
No worries buddy.
OK, how about ''not a good wiring method'' Looping through every switch box on a lighting circuit, leaving a neutral joint that is not needed or required is not a good wiring method... I think i've stated other reasons why previously.
Design the circuit or installation properly using if you like the modern connectors like wago's in wago boxes, at down lighter locations and you shouldn't end up with a massive bunch of cables at one location to terminate. Turning switch boxes into joint boxes, to get past what in truth is lighting layout design problems is not a good solution!!
There, ....never used ''Bad Practice'' once!!! ....Boy was that hard for me!!! lol!!!!
I think it could be time to shut the door on this thread.....
Throwing a shed load of cables into a plastic backbox with numerous connector blocks is what I call bad practise...... popcorn anyone?![]()
How many is a shed load?
You tell me how many have you switch lads got in at once....
Fair enough, but it's a bit old going round and round and round.................
