OK, how about ''not a good wiring method'' Looping through every switch box on a lighting circuit, leaving a neutral joint that is not needed or required is not a good wiring method... I think i've stated other reasons why previously.
Design the circuit or installation properly using if you like the modern connectors like wago's in wago boxes, at down lighter locations and you shouldn't end up with a massive bunch of cables at one location to terminate. Turning switch boxes into joint boxes, to get past what in truth is lighting layout design problems is not a good solution!!
There, ....never used ''Bad Practice'' once!!! ....Boy was that hard for me!!! lol!!!!
E54 is on wind up ,
Dont think E54 does windups....he is sincere in his beliefs.....even if I dont agree with a lot of his opinions gotta respect him for that!
Throwing a shed load of cables into a plastic backbox with numerous connector blocks is what I call bad practise...... popcorn anyone? :p
