S
sivoodoo
Which method would you think uses the least amont of cable, looping in at the ceiling rose or at the switch?
Regards
Si.
Regards
Si.
Discuss Loop in at ceiling rose or switch? in the Australia area at ElectriciansForums.net
I'd be interested to see how you make your lights work without a neutral! When you feed a switch in twin and earth the neutral is needed there to supply the light. You use the Switch as a JB, same thing as a ceiling rose.
Cheers,
Well mate if you were sad about the Reg advising that a box or enclosure now does not have to be fixed to the fabric of the building, you will be raging that the regs now want you to consider the provision of a neutral conductor at each switch position to facilitate the installation of electronic devices in lighting circuits.
So though it mentions electronic devices you may find that the wiring loop at the fittings could be a thing of the past
What electronic devices, and would you need a neutral at every switch in the installation?? I think not to be honest!! I don't have anything against having a neutral at the switch position, but ONLY when a neutral is needed. I would never and have never looped through switches as a matter of course. To-date, i have never seen any official body either showing wiring diagrams or describing switch looped lighting circuits or in any other way endorsing such a wiring scheme.
Part P, eh? Welcome to the begining of the end of a once proud trade.
sorry you'll have to tilt your poor heads but here is the image from the AM2 notes showing feed to the switch for two way and inter lighting in twin and earth.
Look I'm not here to start an argument, it's already been started! All I'm saying is, that in addition to the 'solysta' range from Hager, that it is no longer just a 'do- not' from the old school boys, but a legitimate variation to traditional methods with it's own merits and need to be considered when designing lighting systems. There is nothing in the regs that says you can't have neutral at a switch, you just can't ONLY switch the neutral. There really are no other reasons that it can't be there.
And yes, i did misread a post on here that I replied hastily to so apologies for that. Must learn to read more carefully (lol, note to self!).
Thanks all.
to be honest my sentiments were as your own when I saw it. But you don't argue when they're the ones taking the money off you to assess you do you? I only posted this in answer to the wider debate, most fueled recently by a heated thread (was it even closed?) about neutrals at switches. This is the score, I'm a young entry to the profession, educated to degree level (not in engineering) but interested in intelligent debate. I don't make the rules. I came into the game being shown the feed to the switch method and have seen it signed off time and again. Only in time gained with other sparks to come up against this resistance to the first practice I was shown. now, years later, I've seen all sorts of methods, and I've done the 17th. Having recently read threads on this contentious topic and sat my AM2, and reading the electricians monthly publications I thought I would add (the business') two-penneth worth in the hope that clever old boys would see past the old accepted ways and embrace the new ways based on sound reason.
Regards.
Is there any such endorsement for the looping at light method?
Tin hat on![]()
I would say that they are mere examples or diagrams, not endorsements.
For the record, I don't loop at switches, I'm just playing devils advocate.
"There goes yet another nail into the coffin of our industry!! "
Not really.
Its safer, fact.
Most electrocutions occur when a DIYer switches off the switch and removes his ceiling rose believing it is dead "but I switched it off!" he says. Zap.
Its so much more logical to have the neutral at the switch. Turn of the switch and the light is dead, unless of course the missus comes in a switches it back on.
I think my first question is a bit daft anyway. It would all depend on the circuit arangements, I was just wondering and thought there may be a magical equation
Regards
Si
I'll see if I can find the IET notes for the pre- AM2 with diagram. off to walk the dog now though.
Cheers.
I presume you're referring to the NET (National Electrotechnical Training). Unless I'm missing something I can't see the connection between the IEE and the AM2.
agreed I use what ever method is best suited to what is being installed .I would have thought either method is acceptable as both employ barriers and enclosures as a means of basic protection.....
And...in the case of a new install (17th)....additional protection by RCD........agreed I use what ever method is best suited to what is being installed .
Reply to Loop in at ceiling rose or switch? in the Australia area at ElectriciansForums.net
