use r wrong the regulations state that the sockets have to be 450mm from ground and light switches 120mm to top.If u certify this u could get into trouble because u arnt following regulations.If u rewire a house u have to abide by the regulations at the right heights.Keep yourself right.Approved contractor
A bold statement there Joe, wrong but bold.
Looked in my on site guide and i only have figure 10.7 Insulation resistance
There is a little confusion in this debate I thinks :confused:
Extension at the end of the day,not new build.If you were wiring an extension on a kitchen you'd want to keep everything at the same height.I would personally.:rolleyes:
Do what u like,the current 17th wiring regulations dont give old heights for a NEW extension.If u want to put old heights in go ahead it will be ok for the 16th edition.When u certify this do u mention that u have done this to 16th edition.There has been amendments for a reason.If u also rewire a house u cant use old heights another mistake made by sparks to do with cost.As soon as you touch anything you have to do it to bs7671.The heights off the kitchen counters havnt changed only the spacing from the cooker and sink which is now 300mm and not 150mm as stated in the 16th edition.These r all stated in the 17th edition onsite guide anybody read it
Joe,
The 17th edition has nothing to do with heights of accessories it's approved document M of the building regulations that is concerned here.
With a small one room extension the new heights are not in force it is only full new builds or extensively renovated premesis. What would be the point in making one room compliant when the entire of the rest of your house would not.
It is not your responsibility u have to keep yourself right.I have been doing these for years.
Joe,
Can you quote a reg to back this up?
Im sure many members on here would be very interested to see where they may have been going wrong.
Cheers.
5.2.2 location of kitchen accessories.10.7 access to and use of buildings (approved document m)heights of switches and socket outlets iee 17thedition onsite guide.This guide also incorprates part p
I'm sorry Joe but this is wrong also.
If you actually read Part M it states that and I quote" If the dwelling is rewired there is no requirement to provide the measures described providing that on completion the building is no worse in terms of compliance "
It also states that the requirements of part M do not apply to and again I quote "An extension of or a material alteration of a dwelling.
I'm not making this up Joe, I'm quoting from the electricians guide to the building regs published by the IEE, the same people that publish the regs book and On Site Guide.
joe you are quoting from the electricians guide to the building regulations.
not the on-site guide 10.7.1 read it
bs7671 iee wiring regulations
part p building regulation
approved document M read it
righty, can someone ring up one of your schemes to find out the correct answer,
this is where i'm at as quoted from Part M building regulations page 12/87 http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADM_2004.pdf
it says,
Where the requirements apply
0.1 the requiremtns apply if:
a. a non-domestic building or a dwelling is newly erected;
b. an existing NON-domestic building is extended, or undergoes a material alteration; or
c. an existing building or part of an existing building undergoes a material change of use to a hotel or boarding house, institution, public buiding or shop
...............the regulations then continue onto extendsions etc, but that applys only to newly erected buildings.
check it out for yourself, with this information you can put the sockets at what ever height you want, as long as it was built before ( i dunno 2003?? is it?? ) whether its had an extension on it or not, now if it was a non-domestic dwelling getting extended on an old building, then yeah by the looks it'll need part M taken into account?
that Help any one, or am I just rabbling on 'n' on
Regards Luke
New sockets and switches should according to BS7671 and Part M of the building Regs be fixed at a height that will assist people whose reach is limited.This only applies to NEW BUILDS and DOES not apply if you are adding to EXISTING wiring in your own home or an EXTENSION.Sorry JOE.Agree with a lot of the blokes on this thread:D
old dog I was instructed to buy this guide from a niceic inspector.It is a domestic building with an extension and not a new build were heights r to 17th edition.Luke scotty is right.
chloebear,
Spudnik,
