B
Bul
How would you wire additional sockets in houses that are newer build and furnished.
For example an additional socket in a bedroom. You don't have floorboards to make it easier.
Do you go behind the skirting? Do you slot straps in a stud partition?
I haven't done much domestic in newer houses. There must be common tricks of the trade.
Any advice?:rolleyes4:
you do whatever it takes to make as good, compliant job. if you have to cut weetabix floors, cut them, but allow for the cost of replacing some floor.
Its amazing how architects are paid zillions to design a house and they still cant put enough sockets in. lol
Get a sparks in fella, its not going to cost the earth for a few sockets, its done correctly and the chances are you wont wreck the room as much.
architects... design.... a contradiction in terms there. i wouldn't employ an architect to design an outside bog. probably end up with it flushing upwards as long as it was all curvy and loads of plastic.
Lol, Tel.
Bul, i see from your other posts you do some sparking but with your comment on run behind the skirting i will ignore the fact.
As said above, get another sparks in and you may learn a few tricks that you have not been shown yet.
Actually I did assist a spark and this is how he did the job !
I'm thinking that this might be a common job and that there is a common approach . . .
If you are putting new sockets in make sure you have an RCD. If you modify a circuit that entire circuit needs to be brought up to code.
Yip, thats true.It's the practical side that I have problems with. People don't want the place ripped up or their decoration disturbed, so what appears a simple job isn't necessarily straight forward. . .
Out of interest what certificate, if any did he give the customer?
That may be the case that they don't want their houses damaged but what you have done (or taken part in) is no better than a poor diy job. Doing the job correctly is what divides us from cowboys. I retract my statement of you may learn something from the other sparks. Just tell him to check out safe cable zones/routes reg 522-06, it even has a priddy picture to look at and he can colour it in later with his crayon. Sorry Bul but on a electrical site your not likely to get a well done for that one mate.
Please don't think i'm having a go at you fella, its the spark who said it was ok to do it.
Its a sad fact of life. if you are going to install anything onto an existing installation there will be mess and some degree of making good afterward. I have lost count of the amount of times i have had to tell people that if you put a switch on the wall, and a light on the ceiling, it wont work without having wires involved. This applies to all builds, new, old and everything in between.
Cheers.........Howard
Bul,
Bul,
