Z
Zaffy
My dimmer switch servicing six 12volt MR16 went. Pushed it in and nothing happened, no click. Replaced it with new component. Stil did not work. Replaced the two transformers. Still does not work. Any advice/tips before I call in an electrician?
assuming that each lamp is 50watts, then you are loading a 105 watt tranny with 150watts a 35-105 tranny should be 1 tranny for 1 downlight.
I forgot to say it is a double dimmer the other half of the dimmer works fine and serves an ordinary lightbulb.
I installed a two gang dimmer yesterday. One side worked fine and the other didn't. After deciding it was faulty, being a qualified sparks I decided to poke it with my (1000v insulated vde) screwdriver.
This is no word of a lie. It sparked, made a popping noise and caught fire. It looked like magnesium burning. I turned it off put a 2g switch on and I'll be going back in the week to replace it.
Call a qualified sparks!!
dimmers, the scourge of my life. should be put with the neons under the hammer.
If I do, I won't be calling you.
Faulty switch can hardly be helped mate, And the fact that you've been playing about with your electrics putting lives at risk because you don't wanna spend any money on a professional means I doubt I'd wanna touch it anyway
I shall replace dimmer with on off switch. If that does not work, it is over to the pro.
Looks like we have exhausted the subject. Thanks for all your help.
dunno about the subject, but i'm exhausted. time for a beer.
If you're going to carry on without test equipment then all you can do is replace the dimmer with a normal light switch. If everything works then the dimmer is faulty.
Problem is if the dimmer is faulty you need to find out why otherwise you're going to replace it and the new one could be damaged for the same reason. This brings it full circle back to needing test equipment so I would advise phoning your favorite electrician.
transformers/dimmer
Australia
Zaffy,
Marvo,
