Discuss wiring through joists. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
IMHO where you put the notches and holes is building regs,
Where you run cables is wiring regs.
Yesterday's cables are "selected and erected" to yesterday's wiring regs.
When you select and erect it has to be to BS7671:2011. In this case 522.6.100.
That means just because there's a convenient hole in the joist doesn't mean that you can use it for twin&earth, unless of course you fulfil one of the conditions for mechanical protection. I don't have sufficient wisdom to assert whether a notch plate is sufficient protection.
Interestingly the 50mm is from the top or bottom of the joist not the surface of the floor or ceiling, i.e. does not include the depth of the floorboard. Strange.
Laurie
​that's to allow for 3" nails. bear in mind that the average wood butcher or wet-head will use whatever he has to hand when nailing boards.
How daft, old houses often have joists with more holes than Swiss cheese and they seem to stay up.
that's because they were built, not thrown up designs by pencil pushing bean counters.
I could not care less about BS7671, the first priority of any trade working on site is make sure that at the end of it he/she has not weakened the structure, stuff the regs, use what's there and inform the IET to issue a guideline of old houses with existing holes in joists (weakened joists). Holes in joists should never be allowed in the firstplace!! or should be thinker than required in the first place to conpensate for electricans and plumbers
KC
Reply to wiring through joists. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
