Discuss Has this cylinder been damaged? in the Central Heating Systems area at ElectriciansForums.net
L
LlandrilloSpark
Guys
Called to a HW fault of a heating system, fully pumped 2 plan, 2 X 2port valves
The cylinder is a santon pp120b, the connections are signal in on 1, signal out on 2 and 3 is to grey(permanent live) on the valve, it was wired correctly on 1 & 2 but a neutral was run to 3, has this been damaged?
Cheers
I take it you have altered wiring and it is not working.
I don't think that 3 is used when using two 2 port valves only when using a 2 port with a 3 port so 3 is redundant
Yes your right 3 only used on a mid pos valve, I think there are other issues but I havnt changed anything yet, I just wanted to know if addition of N would damage it
Yes very interesting, Water is heated by a ETA(Austrian) Biomass wood burning boiler, £16,000 worth, water is stored in a buffer tank 2.5m x 1m and then when CH or HW is called for it is pumped from the buffer. CH is underfloor x 5 stats/actuators , both HW and CH are pumped, HW is pumped from main buffer to storage cylinders in question , I've wire one similar before but not an ETA , Boiler is fed via a hopper full of biomass which uses single phase cap start motor to pump the biomass to the boiler
Reply to Has this cylinder been damaged? in the Central Heating Systems area at ElectriciansForums.net
