La Poste
Greetings.
I have a question about timer relays.
Basically what I want is a Din rail mounted timer relay that operates from a trigger pulse from a garage door limit switch.
As the door travels up it hits the limit switch and from this the coil of the relay is energised and hence the relay contacts are switched and thus the garage lights switch on for a set period of time.
Simple you might think well not really.
I have tried a timer relay that I thought was perfect for the job but the problem is this.
As the garage door goes up and hits the limit switch the relay is energised and the timer starts to operate the trouble is if the garage door is then shut the trigger signal to the relay coil is cut and all the lights go out.
What I am after is a timer relay that will be energised by the limit switch signal as the garage door moves up but if the garage door is closed the relay will still complete it's timer cycle.
I don't have a lot of knowledge of timer relays and control circuitry so any pointers will be appreciated.
Thanks.
Thanks.
