K
kduck
Been to a customers house today she wants a TV putting on her bedroom wall so she will need a socket point behind the TV. Customer does not want carpets lifting or holes in the walls, the wall with the TV on is ok as its stud and I can get to it from the loft to put the power in there. So the question is can you use a fused spur off the lighting circuit for the TV, the TV has a transformer down to 12v.
I cant see a problem with putting a switched fused spur in, just check the circuit can take any additional load and is up to spec. (issue a minor works with your invoice)
Ash
Hi.
I would say not as you know it wont just be the T.V, she'll want her DVD player, freeview box etc etc.
It's off of the ring or nothing for me.
Hi.
I know what you mean regarding the eventuall extras she would want, but with the original spur just for the tv and certificated he is covered.
I have had jobs like this in the past ie for projectors etc and when i provided a written quote i also included a letter stating how i would rather do it and that the customer wanted it a different way and if they did not sign it the work did not get done (by me anyway!)
I am a spark that believes appliances should never go on a lighting circuit and i (probably by my attitude and dismay) get that across to the customer and if they are still addiment 'out comes the letter for them to sign'
What about making the socket for the telley one of those small round pin lighting ones so she cant plug hoover etc in? just a thought if you absoutley have to use lighting supply.
I agree with lenny on this one, as i wouldnt personally do it with the assumption the front end mcb fitted is a 6 amp type b it would be prone to nuisance tripping with the inrush on the t.v. transformer which no-one seems to have thought about and upgrading the mcb to a type d would require a check to see the earth loop is still within permitted values, so its a dont do it, tell the customer surface mount or theirs a chance the decor will suffer and let them make the choice.
You should never install a socket behind a wall mounted TV it should always be an outlet plate from an accessible switched fused spur ideally off the ring.
I hate it when sparks put double sockets half way up the wall for a TV it causes major issues and is potentially unsafe!
Its unsafe because sometimes they are inaccessible.
However, if i put them behind the tv i mount them higher up so that they can be reached from above the TV.
thats actually A valid point ave never thought of before, must confess to have fitted the odd socket behind a television, dunno if i would go as far to say its unsafe though how hard is it to take a television off the wall
lol ok point taken
good point though ill keep that in mind next one i get
I've fitted sockets behind wall mounted TVs, the end of the day the customers we've had don't want an exposed
socket with leads trailing, and i agree i wouldn't want it either. If you think about it there no less accessable than ones
mounted at normal height, you'll still have to move the TV/dvd/stand etc to get to it. Can't see the danger myself.
Interesting point made here regarding sockets behind televisions. I'd agree with the comments that relate to having the sockets ( or flex outlet switched spur ) above the television to allow access to them for reasons of electrical testing and ease of connection and disconnection.
I'd also agree not to wire the tv socket to the lighting circuit.
