Discuss I am a new PV householder - advice please. Unbalanced strings and wrong inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Each panel is wired to an optimizer, then the optimizers are connected in series strings as per usual
reading these comments on the solar edge, i am thinking of using them on job with 2 roofs slightly different angles.
I know segen stock thems anywhere else ?
Also is there any other wiring to them besides the DC side ?
and can you excess information from any location thru the web.
Got mine from Segen. No additional or unusual wiring required. However, the main inverter is transformerless so array frame bonding may be required depending on which version of the DTI guide you're working to! Didn't connect up the communications side of things on our job 'cos the customer didn't have an internet connection but as I understand it, you can access the monitoring through the interweb from anywhere (someone with more experience please correct me if I'm wrong)
the best car made in china , would not compare to the worst car made in europe
get them to fit a real inverter suitable for the application ideally a poweredge due to string layout or dual MPPT sma/powerone
I did manage to stand them down over the weekend, so nobody turned up yesterday. Apparently "senior management" are investigating. I had suggested something like a Solar Edge Inverter 3680W 16A AC Clamped - SE-3680 and 16 lots of Solar Edge 250W Power Optimiser + the 16 Suntech 245w panels that are in my garage. Though why I, the punter, has to suggest this {insert deity} only knows.
you signed a contract with them they should supply exactly as ordered or equivalent or better in lieu
example girlfriend ordered a new kitchen , after fitting she noticed work tops where different you know what women are like with kitchens
she phoned to complain next day the MD of the company turned up with one of those huge amercian freezers
free as way of letting her down
and Daytona600 is as good as his word too, he's not just saying it, he practices it as well.
Busy week... The installer has come back saying they will install the quoted GroWatt inverter, use fire retardant board etc.
I am going to struggle to get out of a signed contract where they have offered to comply with the contract.
Whats the worst that could happen with
Growatt 3600MTL (2 MPPTs)
12 x 245w panels on a 30% roof
4 x 245w panels on a 35% roof
Could be wired 8+8 according to Growatt tech support, though that was before I knew about roof angle, and they haven't answered my recent question.
In another thread, FB said
As Gavin says: in summer it won't matter.
But with low sun in winter (or early/late in the day at other times of year), the difference in angle will make a big difference to panel output, so the bypass diodes will be working overtime.
By my reckoning, a 5-degree difference (35 v 30 degrees) in angle affects as follows:
Mid-day, June sun: 0.5%
Mid-day, March/Sept sun: 5%
(comparable to morning/afternoon summer sun)
Mid-day, December sun: 20%
(comparable to early-morning/late afternoon spring/autumn sun)
Will that amount to much over the year?
Is bypass diodes working overtime a big problem?
Thanks...
Thanks...
When did you sign the contract as you have 7 days cooling off period
New posts
Reply to I am a new PV householder - advice please. Unbalanced strings and wrong inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, total newbie to the forum. I sincerely hope that those in the know-how would be able to assist me. On my semi-detached house we have an...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
Hi guys, I am new to the forum so be nice! I used to install solar PV systems back when the tariffs were still good, and I've never had to go...
5K
F
A few weeks ago, I had my solar panels remove from my roof and then replaced. Sadly, on removal, one panel was warped and on letting the fixing...
Hi All got call out to a domestic fault on consumer unit totally separate from the job & client mentions to me that they had Battery storage...
12K
