It seems this thread could get out of hand 1st geordie sparks i don't know Dan? 2nd telectrix i have been a spark for over30 years mostly on industrial and to me a good night sleep and a happy customer is very important
Lol that was just a bit of a leg pull , Dan , a moderator asked the members last night to post new threads to get the post counts up.
well, it that's the case, you should have been able to answer your own question. :rockon:
no disrespect, to you AA4120, but i would have thought that with your experience, you should know that choc blocks floating around without an enclosure was pants.
Have to agree with tel here. Always great to get other electricians' opinions on aspects of our job, but
"all the down lighters have been wired up with strip connectors is this acceptable under BS7671 and dose this comply as an enclosure"
seems an odd question for an experienced spark...
The thing is that the mentality was then is to put a bit o choc block on wrap tape around it and chuck it where no one can see it then someone like me comes along when the tranny dies and finds it melted as it fell on the lamp so I replace the tranny with a loop in loop out model but sometimes there is not enough space so I fit an inline choc box the other snag I hit is the the old reflector spots and they are the same.
The agreement with the letting agent is to put the exposed joint in a choc box but not to touch the rest or in other words let sleeping dogs lie funny thing is this does no get picked up on the rolling PIR they get done (not by me) by a n other
I do agree Guitarist but as i explained most of my experience has been industrial and not domestic so the short time i have had on domestic has been an eye opener and to see what people do to cut corners to save a few quid
you'll see a lot worse than that on domestics, mate. a favourite among the diy brigade is to cram 7 or 8 cables into a junction box, using a 3 terminal box when a 4 terminal one is needed, then twisting the bare cpc's on the outside ( that's if they even bother with cpc's.
and beware of the split ring. this is where diy'er or bob the builder splits a ring final and takes 1 leg to a socket or 2, and the other leg to another socket or 2, thus making 2 radials from 1 32A MCB. if you're lucky, 2.5mmcable has been used. on the 1 i found last year, builder has used 1.0mm 3 core. so 4 sockets were wired in 1.0mm, protected at 32A.
The builders seem to be getting more responsible tel
Just the 4 sockets ? that is impressive, he's obviously got his "part P" cert
I do understand mate, as my background was industrial. I was one of the lucky ones who had a lovely 4 year multi-skilled apprenticeship which covered all aspects of domestic/commercial work too (so that we could cover the site offices).
I'm sure you can see now why we sometimes ask what background people have had, as it really does make a difference to the advice we give.
As tel says, you'll see far worse in domestic, things which simply wouldn't be done in a factory.
Could the regulation about needing to be in an enclosure and Maintenance free connection not be used? (depending on the situation of course)...as strip connectors aren't maintenance free.Then use the line box and connectors as a good/easy replacement. (Line products listed on righthand column of forums...union jack background)
have seen cpc's twisted together outside jb this week, along with connectors and 50w halogens underneath 200mm of insulation and can see scorch marks...i told her needs to be adressed, but she thinks il sort it all for free as im wirining new extension, she can whistle the old bag unless she talks money
