Loox LED 2011 Flexible strip light, single colour
• Set includes:
- 3/4x Loox LED 2011 strip lights, 12V/0.8W, 12 diodes per light, 300 mm length each, white plastic
- 2x 1.5 m light to light connecting leads
- 2x 2.5 m light to driver leads
- 1x Loox 12V LED driver constant voltage, 240V/15W
- 1x Mains lead with UK moulded plug, 2 m length
• Strip lights are self adhesive, can be cut to length where scissor symbol shown
• Order switch separately
THis is the one I assume you mean - I can't make ANY sense out of what that's saying. How many lights at what length is in there? I've looked at these kind of things a few times over the last year and given up coz I have no clue what any are saying, there's just a big vomit of numbers.
This is the stuff I used and then mounted in the aluminium channel they also supply. it pretty easy to follow just look at the related products at the bottom everything works in conjunction
Loox LED 2013 5 m strip light with 300 LEDs, 12V/24W | Häfele UK Ltd
Lol I know what you mean, we ballsed up the order a couple of times before we used the website. I've also used the kit in some bathroom cabinets really good light output and really quick to install :)
When buying LED's ( lamps, Strips, drivers, DMX controllers .,
NO subsitute for quality ( cheap normally = nasty )
