The thing is that your are in a position and so are they that they could have fitted RCBOs and split the IT circuits up
Obviously the cost of splitting RCD circuits for IT is going to come into play, but me personally can't see a reason not to RCD protect virtually all socket outlets these days.
But it is your --- on the line should the brown stuff hit the fan.
Reading this, Makes me wonder how we have all survived without RCD devices over all these years... We should all be dead or frightened to switch a light or socket on...lol!!
I'm with Dan on this one, far too much reliance on the all singing, all dancing ''Cover All'' RCD devices these day's. They are NOT always required on every circuit and in every situation...
Who said they were ? The OP was seemingly criticising another sparks interpretation of the need for RCD protection on his installation, as stated its his call, that doesn't make the other guy completely wrong !
J
J
Eh, ...i'm making a general statement here, nothing more nothing less!!!
Kind of makes you wish 'specialised' sockets were more easily available, like the ones with the T shaped earth pins so you could fit them to computers for dedicated socket circuits and avoid this kind of situation
Has anyone else experienced other sparks going nuts for RCD's and thinking they are required for pretty much everything?
I recently did the installation at my local CEF branch and had another spark telling me I should have fitted a dual RCD board! I reminded him that the install was in trunking and conduit ( no less than 50mm issue) and also not in a domestic situation. All sockets were in The office, apart form an outside RCD socket and a couple of sockets in the warehouse that were on an rcbo ( they were near the door to outside).
He still said "well I think it's good practice to fit them in most situations for optimising protection". I just bot my tongue told him to check his regs book and went on about my merry way.
Dan I really am just looking for reasonable discussion not an argument,but where would have you pointed him to to look in the regs ? It's the bit about your installation not being 'Domestic' that I can't square the circle with in my head ? 411.3.3 states the reasons and exceptions, and you have decided to apply one or both of the exceptions in that reg, again I have no issue with that, your call, are you saying 'ordinary' persons can't be found in a non- domestic building ? so that's a given ?
J
They are readily available I have used them on many occasions , problem being of course is that all IT comes with their own moulded plugs and most people don't take kindly to having them cut off !
J
As long as regulation 411.3.3 is met then what you have done is perfectly fine.
- - - Updated - - -
Just because it is in a office area and may nuisance trip is no reason to by pass the regs.
At what point have the regs been bypassed?
I never directly said that it had.
I would of done the same in a office environment, last thing they would want is all there computers going down just because a bulb goes in a light, or somebody plugs a dodgy item in a socket in warehouse. Looks like you did the best protection for the job in hand.
Makes it sound like there was no other way to carry out the job, therefore the regs could have been ignored?
He provided addition protection where he had a idea other people may plug things in ie near the rear door and In the warehouse. Adding another rcbo to the office sockets would of made no difference to the cost(parts supplied by CEF) so I'm assuming CEF asked for no rcd so as to get no nuisance tripping, in which case would of also had a competent person to see that the sockets were used what what is intended. Ignoring the fact that everything is surface mount and in conduit.
Now I am not getting involved in a argument, but it is down to interpretation. IT equipment will leak to earth therefore causing a RCD/RCBO to trip if to much is installed on one circuit. This is what the OP wanted to avoid. Now the sockets wont be used or constantly monitored by a skilled person. As to do that would be bloody expensive to employ effectively retail assistants.
The customer has not stated they dont want the sockets RCD protecting as again the OP has said he has done the design, install and testing.
So the only way I see it possible to do this would be too.
A. Work out earth leakage of each item of equipment
B. Install enough circuits so that none reach the limits of nuisance tripping
C. Install each circuit on a RCBO
So your saying it has to be RCD protected, even though in conduit and no mobile items will be plugged in? Only the office manager has to be deemed competent to know how to take care of the sockets, they don't have to be a electrician to be deemed competent to know what should be plunged in or not( I may be wrong on this point)
Myself yes I would.
Do the items plugged in need PAT? That makes them portable.
What happens when the manager is off work, out of the office etc ? Too many variables in a office to say only one person has to be competant.
Dan23584,
Deleted member 26818,
