But hang on if you are getting a shock off the earths then there is obviously an earthing issue,if the wiring was earthed then it would go down to earth not make other equipment live!
Is this the same job where you've shown a picture of a consumer unit with two main switches?
No idea yet. It was across the country. So I disconnected the washing machine until I can defintely test this w/e. I'm assuming it is an earth fault loop as the socket screws are not live unless the washing machine is plugged in.
Agreed !!
That's the whole point in having an earth .....
....................... isn't it ?? :whatchutalkingabout :confused5:
Yes. Same place electric will. Although from the CU I can see that the sockets are in fact not a ring.
Phil D, but how about if there is an earth/neutral fault in the washing machine, couldn't that make the socket screws and any other appliance plugged in to be live? (I don't follow why the socket screws and other appliances are not live unless the washing machine is plugged in). Surely just a straightforward earth fault in the circuit would mean that they sockets stay live all the time?
That's why some ones took the rcd out and put a main switch in, you've got and earth leakage and poss a poor earth .
never thought of using it as a tea stirrer, will save the next one instead of putting it straight in the bin!
they are not for either of those uses,you are supposed to give them to people you dont like,then they think you like them and hey you may get lucky,and get your wish.
Please excuse me asking this, but I can no longer contain my curiosity: Are you an electrician?
Presumably whoever worked on the install knew they hadn't found the fault, and knew they had left it in a dangerous state. Wonder who it was? Daz
some washers have a device in them which does give a slight leakage to earth but if its putting a voltage on earthed metalwork,socket screws,appliances etc then the earth is down somewhere along the line.
How about going back to basics and removing all socket fronts checking connections and doing some basic tests and see what the results come up with!
Sorry for being sarcastic just feeling that way out! :vanish:
and everybody stop bickering!
sounds like you may be a bit inexperienced at fault finding,why not post your location and get some help.
gvelec,
kathwilcox,
