P
pencilpusher
Told by who or is this another electrical myth ?
Added to the below thread!
http://www.electriciansforums.net/e...43-electrical-myth-busting-10.html#post648165
Really I was told you shouldn't mix colours and had to sleeve where they meet in sockets etc
Why if thats where they want it? If the external influences do not effect the TV then it is fine IMO
I was thinking of the heat from a 3kW fire derating the plug/socket/circuit to 2kW! Plus, the picture it conjured up in my mind of a something else plugged in with flex/cable hanging down in front of the fire. (with clothes hanging on it to dry)!
And they should have to answer a quick yes or no 5 question test:
1. Do you watch Jeremy Kyle more than once a week on purpose?
2. Have you ever accidentally kicked yourself in the face whilst being convinced if you can get your foot above your head you wont get cancer
3. Licked a window
4. inserted a foreign object into your rectum to see what will happen
5. Are a plumber
If they fail the test, by answering YES to any of the above, then re-direct them to the screwfix forum.
Rant
thing is here though Paul.....if he`s askin about notices at origin....and if its ok to mix colours n all that lot.....the most sophisticated bit of test gear he`ll have is probably the old `neon` driver....Thanks Wade, that has just made my morning![]()
Back to the op. Why has no one asked if the original ring has been tested before making any alterations? Ok it has been said not to over load it but can the op do R1+R2 to ensure cpc is present and ok for Zs?
so....did you see anything you liked the other day Paul?...I know, thats why I asked![]()
Combi and a connect but I'll call you. Dont want to take this thread off track lol
3. Licked a window
5. Are a plumber
