J
Jamie3032
Hi, Does anybody know of any alternative to governing the speed of a 3 phase motor than a frequency inverter? Thanks in advance, Jamie
I was thinking of a very strong pair of gloves.
Railway sleeper works well.
I guess if it doesnt involve T+E you fellas are banging your head against the wall, thanks for the comedic replies though, just amazing....
If it,s a "bog standard" asynchronous induction motor (most common 3-phase motor) your meaning, a frequency converter is the only practical method. There is other more specialist 3 phase motors that can be controlled by other means but these are not very commonly used. Frequency converters are by far the most common way of controlling the speed of an AC 3 phase motor.
You can control them via a potentiometer yes but depending on the make/model you can get a range of operator panels to give them better control and feedback on key parameters. Is the motor existing or to be sourced?
Thanks, yes this is what I thought was the case, i am thinking that the frequency inverter can be controlled via a panel mounted potentiometer
