Discuss DNO Fitting Isolator in the UK Electrical Forum area at ElectriciansForums.net
O
omega
Hi, anyone had the pleasure of having the DNO fit an isolator between the cutout and the consumer unit? I'd be grateful to hear of the costs involved
and the amount of time it takes them to sort it. As we all know, only the DNO can pull the bomb so i'm curious as to costs of an isolator. While i'm at it, anyone aware of problems with the smart meters shutting down if the main bomb is pulled, just curious obviously.
if the meter is one of the modern digital ones theres an inbuilt isolator on some, its a slotted device on the front
Is this the thing on the underneath that says "not to be used as a main isolator" or something? Makes me wonder what its for if not.
Hi,
I had an isolater fitted recently. I was told it would cost £110, I said that was too much so they rang back the next day and said £65 which I agreed to.
Cant quite remember but I think they came out within a couple of weeks (but only after 2 additional phone calls to push them along a bit and remind them).
This must be a couple of months ago now and no bill so far, so I dont actually think they are going to charge :smiley2:.
This was Western Power Distribution. I expect the service and cost varies greatly depending on the DNO.
Good luck..
The contractor switches your referring trip down if the meter goes too far into debt, but I believe they are single pole that is why you can't use them for isolation purposes.
SSE did two for me recently, both for free as they changed out old dial-type meters for electronic ones at the same time. Had another one quoted at £65.
don,t be silly archy, the slot your referring to is where scousers poke the wire from a piezo-electric sparker to kill the meter, one "click" meter display and electronics dead free power
theres a circular flush switch built into the front of SOME digital meters
it has a slot
all u need to do is, using a flat bladed screwdriver- turn it counter clockwize to isolate the supply
i have in the past
I was quoted 115 from Scottish power. Although we have a company called iqa that do all of ours in work. Might be worth seeing if u can get an approved subby in who could maybe do it cheaper? Weve Had a lot of problems with the switches tho. Think there abit of an un necessary addition/fire risk IMO. Heard a rumour sp/sse etc are bringing out new meters that incorporate a dp isolator so that we can renew DBS/tails without cutting seals.??
Think we are missing the point here DNO's should fit one as a matter of course when fitting a new meter But hold on that's too much like common sense plus you cannot charge for it
The new smart meter logs any time it loses power and for how long so if someone starts to fiddle it it brings up when it lost power and for how long,and I would assume they keep a record of power cuts in each area so they can check against these lists if they think someones been at it.
I think you'll all be surprised just how little these new DNO's do actually record. Your more likely find how many records they have actually ''lost'' or mislaid since taking over from the old regional boards, who's records were pretty good!! lol!!
my meter with inbuilt iso
Same here, if I had to wait on NIE it would never have been done
I too have fitted one or two, but it did occur to me might the DNO notice (SSE) and - if they did have records - query where the isolator had come from? Or do they just not have that detailed records nowadays?
Why on earth would someone make a video like this?! And I love the way he's not using an insulated screwdriver and is poking it around the terminals! :D
Who knows? Perhaps he owns the company whose label is stuck on the front of the meter and it's a little extra publicity. I wouldn't employ him to do any wiring for me though.
I think I'll make a video showing round my oven. "Here we have the temperature control dial; moving the pointer in a clockwise direction increases the temperature in the oven to that denoted by these numbers around the outside, ha! which of course are in celsius. Next we have a blank where on another model there would be the grill control..."
and if you ever come across an install that still has the old VOELCB in place.....dont forget that that will serve perfectly well as an iso as well once the earthing has been disconnected from it.....so dont necessarily bin em if you are upgrading...keep em in circuit (tails).....do nicely as an iso and as it was originally designed to break fault...well, it just gets better n better...
I am with Scottish Power and they quoted me £85 + VAT the other day, yet my parents are with British Gas and they are doing theirs for free! Kind of wish I'd stayed with them now and didn't switch!
Aye ..... but in MY case - both cases in fact - the meters were not "Smart" or even remotely clever - they weren't even pretty or remotely attractive either - just ordinary, common or garden meters so there was no fuss, palaver or problem. :)
The isolator is fitted AFTER their meter so it's none of their damned business.
You bought an oven without a grill?? ............. What a cheapskate !!! ;)
Reply to DNO Fitting Isolator in the UK Electrical Forum area at ElectriciansForums.net
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Hello. Just a lowly homeowner here who is beginning to panic after a major house renovation regarding relocation of the main supply cable to the...
I'd appreciate the wisdom of the find minds here regarding this job. Yes, I've drifted into Wales again.... An extension is being planned as...
