C
Craig Jones
Hi there,
I'm looking into setting up a business which will be working in peoples properties. Part of the work that i will need to undertake is the removal of wall sockets and replacement on new ones and maybe the same with light switches. What qualifcations / certificates will i need to undertake the work legally?
Craig
None, so long as you're a competent person and not making any alterations other switching like for like
If it is a like for like swap then none, although issuing a MWC would be highly recommended.
Hi there,
Craig
You don't need any qualifications to do electrical work in the UK.
You do however need to be aware of safe isolation procedure to keep you and your operatives safe. Handy guide for safe isolation is available on the ESC website.
The electricity at work regs would be handy to read through, and approved voltage testers are a must for isolation.
No.....you will know how to do it properly,but the law allows any unqualified Tom,Dick or Abdul to have a go if they so wish.
and your qualifications and experience will be on your side if and when the shxt hits the fan....whereas a plumber doing a CU change will have little or no defence.
jusr reading the htread title and not the posts, my answer has to be............ a screwdriver.
It might be worth checking with the company which provides your professional indemnity insurance before you get the van signwritten.
