K
kingeri
I'm currently working on some general improvements and fault rectifications on an unoccupied house, in my spare time. I've found that the living room ring and the kitchen radial are joined, so both remain live when one of the breakers is turned off. I've found the offending connection, problem is I can only disconnect it from the living room circuit as it joined to a socket. At the kitchen circuit end it must feed from a JB which is totally inaccessible, behind kitchen units. I've disconnected from the living room circuit, but obviously this has left live conductors from one circuit in an accessory from another circuit. I left it terminated into a wago connector and taped up, at least for now. I'm not happy with this at all, but can't see an immediate solution, any ideas?
