Based in SheffieldNot sure about uilt in keypad one, but there maybe a tamper (separate to the zones one Telectrix mentioned) for extra keypads, they have their own tamper.
But not sure as always fitted G4's with a separate keypad.
Its a process of elimination.
good luck!
- - - Updated - - -
Simbin where yerz based?
Its not a remote keypad-built in! Thanks anyway!!Open lid on remote keypad and using lid activate tamper switch 3 times then screw lid back on this resets tamper
I'm not back on the job until Monday but have plenty of solutions to try. I didn't know how to eliminate the bell, its the only thing I haven't tried. Looked at all the fuses & they seem ok. I'll update you when its working (!). Thanks again.start with the obvious. link out the global tamper and see if it clears. if not, link out A and T ( 0V and tamper return) to eliminate the bell. then check to see if you've blown a fuse on the board. this could be a cause ( using the tamper light to show there's something wrong that the panel don't have a light for). then, in future use gardtec eurosec panels. far superior and with LCD display.
10 - 1 it's the bell tamper switch not making. some need the arm bending. on most modern bell boxes, the tamper switch makes on the wall behind the box as well as on the cover.
