Hi,
Just thought id share my work with you, I did this board change this morning, I was contemplating extending the circuits, but managed to get it all to fit quite well, quite neat considering.
Had to put new bonding in and tails and main earth which was a pain dragging it down through the cavity. I had to pull the main fuse in the end despite having WPD out last week to fit the isolator, I then realized today I couldn't get the earth in without removing the fuse!
Started at 7:45am and finished a 1pm, fully tested, inspected and all paperwork done.
2014-06-23 07.20.15.jpg2014-06-23 07.24.25-2.jpg2014-06-23 07.35.37.jpg2014-06-23 07.39.33-2.jpg2014-06-23 07.39.54.jpg
2014-06-23 08.00.37.jpg2014-06-23 08.16.00.jpg2014-06-23 08.18.40.jpg2014-06-23 09.09.06.jpg2014-06-23 09.42.17.jpg
2014-06-23 11.10.27-2.jpg2014-06-23 11.33.03.jpg2014-06-23 13.01.16.jpg2014-06-23 13.01.53-1.jpg
only way out would have been to split the rfc into 2 radials ( each on a 20A MCB, of course ). not advised if there's any heavy loads.
Hi,
View attachment 25339View attachment 25340View attachment 25341View attachment 25342View attachment 25343
View attachment 25344View attachment 25345View attachment 25346View attachment 25347View attachment 25348
View attachment 25349View attachment 25350View attachment 25351View attachment 25352
its OK but listen sunshine...
stop using MK boards....their dogshyte...
It probably wouldn't be too bigs job to split, but that's a job for another day if he wants it.
I quite like the MK boards, I tend to stick with them as have quite a few spars in the van, maybe Fridays board I'll try hager.
If there's only 1 socket circuit the lights should go on the other rcd. Jmo.
Ive switched to hi integrity boards or RCBO boards now as better more flexible solutions for now and the future!
for what you pay the BG boards are to beat so far....
nice busbar in them as well.....the enclosure is more solid as well......just a better board
Iv heard of some saying they`v had probs with the RCDs.....i never have...and i`v fitted quite a few of em...
It always comes down to price though and until RCBOs come down I don't think I can sell hi integrity boards at a price that people really want to pay.
I have installed a couple recently leaving the non protected as the spares! The most recent one I left the garage db circuit on an mcb only so the garage/garden circuits wouldn't affect the house
Surface run. Good ir. R1 + R2 as expected. Zs the same
OK but the point i was really trying to make Murdoch is that you have implied that there are dodgy finals coming off DB2...so you havn`t given it additional protection....which leads me to ask:
any additional/fault protection by means of RCD in the shed?
So Glenn, would you tell the customer you can’t connect power to their garage DB before or after you’ve started the job?
Before, you loose the job.
After, the customer is liable to shove your regs book where it will need surgically removing.
well i wont leave myself open to any possible `examination` by some `authority` someware...
but i will reduce potentials to a minimum...wherever i can...
Oh, just shove it on an rcbo, that'll show him he has a problem, at least.
One comment, ...why not use a bit of blue heat shrink on those neutral connection ferrules, and also maybe cut the length down a little too. Sorry i just have a pet hate of seeing bare conductors within CU/DBs etc....
You can get yourself a nice 10W schneider enclosure with 6 SPSN single module RCBO's with all appropriate bussbars and blanks for about £120, cheaper than doing it with many brands of SP RCBO and it gives you proper segregation of circuits.
Market Harborough
This morning's bit of handy work
uksparks,
GLENNSPARK,
