- Sep 22, 2020
- 60
- 4
- 1,183
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Trainee Electrician
wanted to add a socket to the wall for a tv on the wall/stand:
so I want to add the socket on the wall at the end of the vid by taking it from the socket thats upstairs. (is it ok to do that and if theres 1 cable only going into that socket am I correct in assuming that it's a radial circuit or it's a spur on a ring, also a ring would ideally be on a 32amp cb wouldn't it)
(these are the downstairs sockets i assume on a ring cause of the 2 wires and is the single socket with 1 wire i assume it's a spur, (was a single gang socket(wire going from the white box just abit up on the wall for a single socket but electrician removed the socket and left the box)
whats the easiest method to add a socket to the wall. ( can rip out floorboards they will be getting renewed anyway)
View attachment Video.mp4View attachment 30sec.mp4
