Discuss 0.5mm T&E cable now available. in the Lighting Forum area at ElectriciansForums.net
It can be for sure. An added safety level.
Have a 3A mcb and a few 5A round pin lighting sockets and plugs, supplying table lamps with 0.5mm flex plugged into the 5A sockets, then the 3A mcb covers it all.
The same thing (ie lighting connected to 5A sockets) is commonly done already with 1mm cable and 6A MCBs. The 0.5mm flex offers minimal advantage and possible disadvantages as discussed.
I had neevr seen it installed or for open over the counter sale until around 10 years ago. That does not mean it was not there.
I've been using 1.0mm2 T&E for domestic lighting circuits since metrication, and have never come across 1.5 installed by anyone else in 'normal' houses. The only time I've used 1.5mm2 is in very large houses where VD, etc., come into consideration.
Local wholesalers have always had pallets of 1.0mm2 T&E on the floor, but only a few reels of 1.5 on the shelf.
I was using 1mm T&E in 1979
Rule of thumb is not a correct method for circuit design what is 'paramount' is correct circuit design based on many factors.
You are giving an opinion. The fact is that rule of thumb was the normal for domestic lighting cable sizing in using 1.5mm. Few ventured away from that size.
Most of the time lighting cable was vastly oversized.
I would say that you are giving an opinion also. Unless you have facts and statistics from across the UK with which to back it up.
It is an opinion based on fact whilst rule of thumb is based on what exactly. Using 1.5 for domestic lighting circuits is not the norm as I have already stated 1.0 has been in use for at least fifty years. What are you basing your 'opinion' on.
I moved into a new developer house in 2001 - I am not there now. All houses were wired in 1.5mm lighting. Until LEDs became the norm, I have never come across any new build or rewire using 1.00mm lighting cable. Not one. I am not making this up. Your experience is 100% the opposite of mine.
Reply to 0.5mm T&E cable now available. in the Lighting Forum area at ElectriciansForums.net
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own. I also read somewhere...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
