Search the forum,
Discuss 110V site transformer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
markym001
Hi all,
I'm new here but looking for some help with wiring a site transformer.
It has a 32A 3-phase supply. I can see the terminals where I wire the phases in to but I cannot see where I need to connect the neutral. The transofrmer will be dropping the voltage to 110V.
Where do I connect the neutral to? All help will very much appreciated.
If you ned any more information then please let me know.
Thanks in advance,
Mark
If the primary is delta wound it will not have a neutral connection so you need to check the primary configuration
I have got the transformer working - thanks UNG. Could anyone please explain how this works without a neutral from the 3-phase supply.
Many thanks.
NO Neutral required Having done 100s of site trannys put an earthclamp(bad practice I know) on your swa as when OINKS on site move tranys they dont care or notice that they have disturbed your gland and an earth clamp will at least keep the swa earthed Im assuming you are using 4core swa
Reply to 110V site transformer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
