Discuss 16 amp commando sockets. 20 amp mcb on site guide as maximum value mcb in the UK Electrical Forum area at ElectriciansForums.net
You have had your work queried during a subsequent inspection.
You know that the situation is not contravening the wiring regulations and the inspector cannot provide a regulation to match the C2 coding.
Advise the customer of this and finish the discussion.
Unless anything further comes up there is nothing to pursue.
You can consider the merits of the comparison of the protective device and the rating of an accessory but that is not really an issue in this case despite what you have mentioned about the loading and MCB operation. So long as the socket is not taking more than 16A then there is no problem.
Reply to 16 amp commando sockets. 20 amp mcb on site guide as maximum value mcb in the UK Electrical Forum area at ElectriciansForums.net
We own a small, one bedroom flat (built 1989). An EICR inspection raised three C2 observations and recommendations: (A) The shower cable, and...
4K
Hi I am a sparks from the 15th Ed, did 16, 17 and last year 18th. I am out of practice though as have been office based for 12+ years in a...
When caring out an EICR on a site I found that the 110 volt socket outlets were connected as three 2.5mm ring final circuits each protected by a...
5K
B
Prefix - I've tried to post this in automotive, but it would not let me. This may be because I have not been recently active. Apologies if this is...
Ok, so I'm registered with Rated People. I don't use them very often but once or twice I have purchased a lead that has turned out to be very...
