Discuss 2 way switch in the Australia area at ElectriciansForums.net
Hi there. Im a 1st year apprentice and I know how to wire a 1way switch..........now i want to know how to wire a 2way. Then after that, i suppose its the intermediate switch!! Could someone post a wiring diagram of a 2way switch please.
appreciate your help
kallam
Two way + intermediate switching using 3c/e
Ultimate Handyman: three way light switching
Two way switching using 3c/e
Ultimate Handyman: two way light switching
The above are pretty much the norm these days, but you could use a JB & terminal strip that isnt so common now.
hiya easy fox. i am correct in saying these are the conversion methods of a lighitng circuit diagram?
regards luke
Yes they are, but now seem to be used as standard installation practise for 2way lighting.
Quite a bit easyier than using the JB method.
Thought I'd dig up an old thread instead of starting a new one.
I don't feel I have ever properly learned two way and intermediate switching and I really need to sort this out. I am almost OK with 2 way switching as long as the 3 plate method is used on the light fittings. But I am second fixing a house at the moment where the lights have been wired with the mains going to the switch and not three plated at the light. Can anyone show me any diagrams of how to do these.
Thanks.
The same way - take a 3 core between switches, then at one switch permanent live and switched live to L1 and L2. The only differences are the 2 wires going to the light are switched live and neutral, the permanent live coming straight in from elsewhere.
The intermediate is done exactly the same way - strappers into the switch, common in terminal block.
Conduit method neutral and earth to the light fitting , two strappers one to L1 of the 1st switch to L1 of the 2nd switch ,the other t o L2 of the first switch and to L2 of the 2nd switch , permernant live to common of the 1st switch and from the common of the 2nd switch to the light fitting. and if the switch requires an earth ,drop an earth to it
This is my version of events.
From incoming supply into a 4 terminal block - neutral [blue] direct to lamp holder, line [brown] to L2 of first switch.
3 and earth between switches - common [grey] to L1 of both switches {or direct connection between first and last if intermediate switching of 3 or more switches is required}
Brown to L2 {together with brown from supply terminal block to switch 1} to L2 of switch 2.
Black to L3 { together with blue [switch live] from switch 1 returning to terminal block} to L3 of switch 2.
Remember all conductors to have brown sleeving.
Hope this makes sense.
Don't panic when you get zero readings when undertaking Insulation Resistance tests due to at least 2 cables making contact when the switches are operated. Repeat IR tests with switch positions changed to confirm satisfactory results.
Good luck
Conversion method
Conventional method
Two way & intermediate switching coventional method
Two way and intermediate conversion method
I still have to draw myself a picture to remind myself each time. It's not something I do very often (once a year?) Ifind understanding what switches what helps a lot!!
Hi there question about intermediate can someone tell me how to wire an intermediate switch with the switch live there or a diagram would be great thanks in advance.
Onece you have connected the switching up as in diagram make sure on sw 1 the feed goes line - L1, swL - L2 ! if your having problems did you wire it yourself ? or was this an alteration from 1 or 2w switching ? or was it already there ? ( remember sometimes you can find only N switched ) make sure you have good connections if need pull out cables and reconnect them ! you might have over tightend them and broke a wire or the terminal screw might be biting on the flex ! if all's ok check at lamp and i know it sounds silly but check bulb.
Hope this helps !
kung.
Reply to 2 way switch in the Australia area at ElectriciansForums.net
Hi All, Pretty comfortable with wiring lighting until I came across needing to install 2 way dimming with a Retractive switch. I didn’t even know...
Hi all, currently doing a job at a house where there are 3 switches In the hallway to control the hall lights. All 1 gang switches, one at...
i know about the different wiring arrangements for 2 way light switching. i want to connect the permanent live into first switch common, connect...
