Discuss 2 Zone fully pumped heating system in the Central Heating Systems area at ElectriciansForums.net
vbyrne
Hi all I am looking for a schematic drawing for a 2 zone fully pumped system comprising of
fused connection unit
timer
2- 2 port valves
corculating pump
Room thermostat
Cylinder thermostat
wiring centre
boiler
hope you can help
And if you don't have much experience with heating wiring you could use one of these a Honeywell Sundial Plan Wiring Centre as they are pretty fool proof as every connection is labeled up.
Reply to 2 Zone fully pumped heating system in the Central Heating Systems area at ElectriciansForums.net
Up until now I have steered clear of heating systems. I now have quite a bit of work with a builder and will be expected to deal with the...
For the past few years, I have used a hydronic system (outdoor wood boiler) with both high and low temp working simultaneously. The low temp...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
