Hello everyone,
This is my first post, so please bear with me. I am trying to work out how the motor to my table saw is wired. I bought it second hand and I think the previous owner has messed with it. One of the brush holders had been forced in and was touching the commutator. I am wondering whether to bin the motor and replace it with a new one. I have replaced the brushes and sorted the brush holder, and the motor turns by hand, but not when switched on.
The winding had burnt out the winding at the connection, which I have desoldered. I am pretty confident that the winding is now ok. The previous owner had replaced the 5amp plug fuse with a 13amp one, presumably when the fuse blew. So it is not surprising that the winding would fail before the 13amp fuse.
I am confused about the way the field windings are connected.
The field has two thicknesses of winding, a very fine one (underneath) and a thicker one on top of the finer one.
The cable from the switch (an NVR, overload switch and small flat capacitor) to the motor has three cores plus earth. I can't work out from the switches how the mains cable two core plus earth, changes to 3 cores plus earth.
One core goes to the one of the carbon brushes and one goes to the thin winding wire and one to the thicker winding wire. There is another wire coming from the thicker winding wire which goes to the second carbon brush.
What I can't work out is:-
1) why is there a single wire going to the thin winding wire? What is the other end attached to? Is this a starting winding or something? Is this 'extra' wire a switch wire?
2) is the wire coming from the thicker winding wire to the carbon brush attached? Is the thicker winding attached only to the incoming and out-going core?
3) are both the cores coming into the field both live or neutral? (or one of each?)
4) if I wanted to bypass the switches and the mains cable and connect the motor up to a 12 v car battery to try it out, can I connect two of the cores to the + and one to the - ? Or is that a bonkers idea?
Thanks in advance,
Steve
Welcome to the forum :)
Your post although imformative with regards to your confusion it doesn't tell us much about the motor, there are so many variations out there we cannot really advise you on the info given, is there a motor plate with details, single phase motors can work in many ways so unless we can figure out what you have then we will be guessing with our replies.
Thank you for the kind welcome!
If only there were any available info about this motor. It is a SIP 01930 table saw. The motor has no plate on it at all. It is made in China to a low budget;)
I will try to take some photos to show what I am talking about.
Best regards
Steve
The extra field could be either for self-excited regenerative braking, or a compensating winding; In either case I would expect the motor to run as a series universal without it. If there are no electronics involved e.g.soft-start, the switching probably applies mains between one end of the series (heavy) field and the armature (you indicate that the series field is in one piece, rather than half in each brush lead as is more usual.) I would take a guess that the leads from the motor are line, capacitor and common neutral.
Disconnected from the switching, the main circuit (arm and series field) might well run slowly from a car battery if there's not too much friction. But testing continuity through the circuit should be sufficient to find the fault (resistance will be variable due to carbon brushes).
FWIW Lucien's Second Rule of DC Machines states that most machines of any voltage between about 1/2cwt and 2 tons weight will do something when connected to a car battery. See: https://www.youtube.com/watch?v=oTeAp6sEHSI
Here's an update, I am pretty sure everything is wired as it should be. I have checked all the connections and they seem to be ok. The capacitor is around 30mm x 20mm x 6mm. It says on it 0.33mF K X2 and under that MEX GPF 40/085/21/C 250v~ 275v~.
Now I reassembled everything, the motor hums loudly, for a couple of seconds max, doesn't turn then it blows the fuse in the plug.
I note the following advice on a motor manufacturer's trouble shooting page:
[TABLE="width: 100%"]
[TR]
[TD="class: boldtext"]Stator is shorted or went to ground. Motor will make a humming noise and the circuit breaker or fuse will trip.[/TD]
[TD]Disassemble motor and inspect windings and internal connections. A blown stator will show a burn mark. Motor must be replaced or the stator rewound.
[/TD]
[/TR]
[/TABLE]
I was wondering if the capacitor needed replacing, but this points the finger at the motor. Unless it is something obvious, I'm not sure I will be able to spot a problem with the stator windings.
I can get a replacement new motor from the saw manufacturer for around £75, so I am thinking that may be the best way forward.
I don't want to do that if it could be something cheap (e.g.capacitor) causing the problem. Also I don't want to spend £75 to find it makes no difference;)
Any advice very gratefully received.
Cheers
Steve
Hi Folks,
Me again.
To save anyone spending their valuable time answering my questions, I've decided to go ahead and buy a new motor.
If nothing else, this exercise has revealed to me:
a) there's no such thing as a real bargain;
b) if I'm having to ask questions like this, I probably shouldn't be messing around with electricity!
c) I have forgotten much of what I knew when I did O' level physics; and
d) this seems a really nice forum with sensible folk, who have time for newcomers:)
Many thanks for help.
Steve
Hi dude,
a) 99% correct
b) possibly
c) I can remember most of it,loved the subject! (did 5 years of French-couldn't give you 10 words...)
d) a hasty,rash and sweeping statement...but pleasant,and gives us something to aspire to...
Good luck with your equipment,and take care,a young pal of mine,removed his thumb,to the wrist,with such a device! :nonod:
Disconnect the drive from the motor, so there nothing attached to its spindle - with mains off check its mechanically free to rotate - apply mains and hand spin the spindle (before the fuse goes) - if it runs then it might be needing a start capacitor - this might have been removed for replacement.
Google start capacitor for an image
It's a universal motor though Sean, so doesn't have a start capacitor!
I can see the sense in cutting losses and replacing - sometimes life is just too short (-circuited). The troubleshooting guide that made that rather broad generalisation is probably referring to induction motors, not universals, but the result is coincidentally similar - windings probably FUBAR. It was worth a quick look though.
quote Lucien "It's a universal motor though Sean, so doesn't have a start capacitor!"
Lucien may have hit the nail on the head its not a start capacitor its for suppression and it may have broken down and shorted (seen this a few times)
May be worth just removing it.
The fuse 1600/230=6.95A so should have a 10A or 13A fuse (but should have run without load on a 5A)
It does sound like the windings or more likely the armature windings are shorted
I have just been in the garage and messed about with the motor a bit more.
I discovered two things:-
1) if I take the armature out and turn on the power, there is no short, or it is not apparent - the fuse does not trip. Is that to be expected? I also put a multimeter on the armature and can find nothing obviously wrong - no sign of melting etc
2) I took the brush holders out and noticed that they are both slightly melted at the business end. I also noticed that they can be moved in and out. They were in as far as they would go.
Tomorrow, I am going to see what happens if I reassemble the motor, but with the brush holders 2-3 mm further out. I am wondering whether the brush holders are actually touching the commutator, or the brushes are pushed so hard against the armature that it is not turning as easily as it should.
Does that sound like it will make any difference?
Cheers
Steve
Cumbria
240v 1ph 1600W Table saw motor wiring question
Steve Blackdog,
Steve Blackdog,
