I’ve got an old DB at work that I’ve had a look at and can see they’ve used the main earth into it and tied it to the neutral connection at the board is this correct?
Not normally correct for a standard DB, you may find this on big industrial type switchboards with a TNS incomer (often with a private transformer not a DNO supply)
Can you post some pictures and more details please?
