Discuss 3 phase distribution board in the UK Electrical Forum area at ElectriciansForums.net
I’ve got an old DB at work that I’ve had a look at and can see they’ve used the main earth into it and tied it to the neutral connection at the board is this correct?
Today - very much a no as that is TN-C within the installation which is no prohibited by the regulations (not sure if just BBB or under the ESQCR).
But I believe historically there are some TN-C installations from long ago, hopefully others on this forum know a lot more about that than me!
Not normally correct for a standard DB, you may find this on big industrial type switchboards with a TNS incomer (often with a private transformer not a DNO supply)
Can you post some pictures and more details please?
Pictures of DB
And the source of energy is?
Reply to 3 phase distribution board in the UK Electrical Forum area at ElectriciansForums.net
Hi Looking at a job currently adding a 3 phase solar installation but the distribution board is full obviously a new board is the best option but...
When there exists a single-phase transfer switch within a 3-phase distribution system, is it necessary for both feeds to the transfer switch to be...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
See attached photo of my new 3 phase supply at my house. Tails supply a Schneider 3ph board. Sparky is in two minds about the correct earthing...
