O
Ogeerster
When starting 3 phase synchronous motors, they require a high starting current 4-7 times the full load current. If this current is taken from the 3 phase supply, the phase windings will burn out, to prevent this, they use starters to start 3 phase synchronous motors.
There are some methods of starting:
-Direct-On Line Starting
-Star Delta Starting
-Auto Transformer Starting
and there is Resistance starting. I have never came across Resistance starting before so if anyone has any knowledge about resistance starting with respect to 3 phase synchronous motors, i will very much be grateful.. Thanks!
Resistance starting is a method of starting that reduces starting currents by using resistors in the start up. Much like star delta starting reduces start currents variable restance is applied to motor winding a its highest to start and reduced to run.
3 Phase Synchronous Motors
Electrician Talk | All Countries
Ogeerster,
Ogeerster,
