Discuss 3 phase to single phase in the Canada area at ElectriciansForums.net
S
sparkysean
hi,
i have a 3 phase 125 amp CCU, i want to step it down to a single phase board with a 6A output, does anybody have any idea where i can find this type of isolater as i cannot seem to find one online. I have tried to order a 6A breaker that fits the CCU but every breaker i have had does not fit the old style board (it's from 1989). Thanks.
hi,
You say you have a 3 phase board but just want to use it as single phase with a 6A output.Are you just using it for a lighting circuit or something:confused:Is the 3 phase board feeding anything at the moment
it's a wylex board and i'm installing a feed for a fire distern, the board has plenty of spare ways and at the moment it's only using 2 32A ways for the AC's in the lift motor room, also does anybody know of any good Maintenace engineer forums (yes i'm in maintenace now, but it's a good job to have if you want to further your studies as i do so say what you like i don't care and anyway you get paid more than me so shut it) haha. thanks
i have had 2 different types now, i will get the exact number tmrw and if anybody could help me find a single phase MCB from 1989 i will be v happy
Reply to 3 phase to single phase in the Canada area at ElectriciansForums.net
Recently started a retrofit where the 3 phase dB has been fitted with bushes through the galv trunking. The single phase supplies outgoing have...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
I have been asked if I can wire a motor for a car lifter in a domestic garage, however the motor is 3 phase and only single phase is available in...
