Hi,
Hoping that someone can advise before we go ahead and instruct a qualified electrician to carry out this job.
We currently have a white plastic 8 Gang Grid Switch Panel in our kitchen but following some recent tiling would now like to change it for a similar fitting but in polished chrome.
I have added some photos of the existing grid panel both with cover on and off and also the type of fitting we would like to change it for.
Once the face panel is removed the 2 rows of 4 switches appear to sit on a metal panel which in turn are screwed to the back box, which appears to be quite a deep set fitting.
Can anyone advise if changing like for like in this case will cause any major issues?
The BG Bespoke 8 gang gridswitch panel is around ÂŁ50, so a fairly expensive outlay if it ends up being something isn't compatible.
Many thanks,
Many thanks,
