Discuss A question about reading electricity meters? in the UK Electrical Forum area at ElectriciansForums.net
S
Steven Brooks
Hi friends,
I am in a rental property and the main electricity meter supplies two properties. An additional meter reads the consumption for the second property. However the main meter has on it 500Imp/KWH but the meter for the second property has on it 1000Imp/KWH. I am assuming I can't just subtract one from the other to get the usage for each property. Can anyone advise on this?
Thanks and Regards,
Steven
Hi Steven, no one else had replied so looks I'm in thr frame.
electricity meters all register the usage in KWH which gives a reading in kilowatts, all meter makes tend to use impulses per kilowatt.
In your case eg 500imp/kwh, this is the little red light that flashes 500 times per KWH. It matters not how many times each meter flashes as the reading they display is the part you take note of.
Yes you can subtract one from the other to get the usage but be aware that the first part (normally 225 units) is charged at a higher rate than the following units so this figure would have to be charged by you to the tennant pro rata as it would be illegal to charge more than the chargable rate for fuel taking into account reasonable collection charges. more information can be obtained from the goverment website for rented properties.
Hope this helps you.
Reply to A question about reading electricity meters? in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Good day readers, if any,I am an old sparky, a very old sparky. I can remember old Faraday giving us lectures Wednesday evenings at evening...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
