Discuss Adding a Fuse Spur on to a Consumer Unit Circuit in the UK Electrical Forum area at ElectriciansForums.net
Any electrical work must be tested and certified.
Whether an alteration to an existing circuit (spurring off ring) or installation of a new circuit.
Do you do any paperwork to record the IR and earth loop values?
Obviously spurring from ring is easier to do. Isolate power first. All good….
But working in a board… you have to isolate the entire board… and you can’t do that without a service isolator before the board. The tails in the top of the mainswitch would still be live.
How does your company insurance deal with this?
We are not having a go at you, you’ve still got a trainee badge, and it’s your job to ask questions….
What we are concerned with is why, if we do the same job, spur off a socket to a fused outlet… we would have a 5 page document to fill out whereas alarm engineers, CCTV, gas installers….. can all seem to rock up and get on with it.
Off topic but if you take a 2.5 spur from a 32A ring final MCB to a twin socket that could have two 3kw heaters plugged into it you will get 5 stars from the NICEIC for keeping to the regulations yet if you wire a twin socket from a 32A MCB that has nothing else in it you are the most dangerous spark out there yet it has exactly the same characteristics.
If you know that the user intends to plug 2x 3kW heaters in to the socket then you design a better solution.
Why would that make someone a dangerous electrician? There's nothing to say a twin socket can't be fed from a 32A MCB.
As above but also why would adding to the 32 mcb that already has an existing circuit or not make a difference, I suppose the 2.5 supplying the double socket is less likely to overload as the extra load on the 32 mcb from the other load is added to it is the only thing I can think of causing it to trip sooner.
Alarm engineers is a loose term. Anyone can program an alarm. I love the arrogance they have about them sometimes
Some (not all) consider themselves engineers because someone has told them what the engineers password is for the alarm.
therefore they can do more than a user and consider themselves an engineer by title.
however, i have met some that are true engineers and understand how the sensors work, what the various signals and resistances passed down the cables are etc.
I can think of one guy who works for a well known alarm company, whose knowledge of electrical systems is incredible (not simply alarms). Unfortunately he is a one off and his colleagues conform to my earlier, lazy stereotype.
Same here, good ones are hard to find in any trade.
One of the ones today was it’s okay for our alarm panel to work from a switched FCU to a unswitched FCU as long as it’s spurred from the live side! 🤯
I just didn’t have the heart to tell him that he was talking absolute rubbish.
Extending or spurring from a circuit.
Am I missing something here?
Reply to Adding a Fuse Spur on to a Consumer Unit Circuit in the UK Electrical Forum area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
