Deleted member 9648
Hi Guys and you advise.
Im adding an additional light fitting and switch to a new downstairs toilet.
Can you tell me if this work needs to be certified and if so where it states that this needs to be certified as im struggling to fine a source for this information.
I have read official goverment guidlines that state for small minor alterations, nothing is required, then on the other hand some say a cirtifate is required.
All im doing is adding a couple of wires.
Cheers
If you are competant to do the work go ahead....As long as it's not a new circuit or within a bathroom or kitchen no requirement to notiify B/C. Part P does require that all installation work in domestic situations must comply with Bs 7671. This means earthing,bonding and circuit protection for your addition must comply with Bs 7671,and it should be tested in accordance with the requirements of 7671....Your call.....I'm not one of the posters on this forum who think only an electrician is capable of carrying out minor installs in domestics,but only you REALLY know if you are capable of doing it safely.
