Discuss Adding Shaver Socket in Bathroom in the Electricians' Talk area at ElectriciansForums.net
Damon
Happy New Year!
Thinking of adding a shaver socket in the bathroom, Am I okay just to add this from the last downlight ?
And if I also add a vanity light can I also just take this feed from the shaver socket also...
So from downlights to shaver socket to vanity light fitting or the other way round....YES?
I understand about notifiable work but have a friend of a friend who can hopefully do me a good deal on the testing and paperwork.
Happy New Year!
It's easier and often neater to find a vanity light with a built-in shaver socket.
Not quite how compliance with Document P is achieved....
Cheers Jason.S, Ya know I was thinking about that switched feed .....so basically that means that the shaver and vanity unit will only work if i actually have the bathroom lights on, correct?
And to avoid that then i need to take the feed from the COM port(feed in) and Neutral rather than L1(switch line) & Neutral point at switch.
Reply to Adding Shaver Socket in Bathroom in the Electricians' Talk area at ElectriciansForums.net
Hi everyone, I had a shaver socket installed inside a bathroom wall cabinet. It makes a constant humming noise that can be heard in the next...
7K
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
For the bathroom, want them matching and one needs to go over the shower. Also need to be ok with insulation over the top. Ideally fit in the...
