Guest viewing is limited
H
harry olee
I discovered this whilst removing tiles in my daughters kitchen.
It disintegrated when i touched it with the sds drill
No enclosure just a backing plate rawl plugged to the wall and plastic terminal blocks behind.
As its unsafe and exposed I need to repair it as quickly as possible.
There isn't any cable slack to play with for use with a wago MF box..
I was going to use an wiska adaptable box with wagos but ideally a metal double socket box with a surface mounted plastic blank plate would look better when she has it re-tiled
Is it ok to use wagos in other enclosures even if they are accessible?
Is there a better alternative arrangement?
Are you just changing the tiles or changing the whole kitchen if it's the latter it could beneficial to replace the cable between the points and mechanically protect properly, or using the same reinstate the point in a suitable location.
I would want to be sure what exactly is going on with those cables. You have four cables. Are they a ring or spurs and what are they supplying. I think when I knew that I might consider where I am going to go from that point of knowledge with those connections.
They are 2 spurs supplying sockets for the freezer and boiler.
I'm just repairing what was there really.
I look at the cu tomorrow.
There is an electrician who is employed to carry out maintenance .
this may be his handy work, he mounted a j201 junction box outside
smashing up some body property is not good .especially tiles of walls
my advise to get permission first ,if you start working on some body property.
especially some body electrics and your daughter a tenant you might do more arm the good.
I gather you are a spark .
I had a guy who rang me up , can you do a job .do you own the property, no I'm the tenant
speak to you land lord he lives in Thailand ask him first .can not get hold of him. tuff
and you wander why they houses are cannabises farms.
"and you wander why they houses are cannabises farms."
Buzzy Lad, I know you are probably using some kind of mobile device, but is there any chance of doing a bit of proof reading before you hit the "send" button? Just so us traditional guys can read your posts in a nice smooth manner.
I mean, we have had quite a few mind benders over the last few days, one that Pete flagged up that I can't bring to mind now, and then there was a "Habitual" room, which I guess was a habitable one, not one where you would smoke a joint.
And now we are wandering where we should be wondering, and they houses that should probably be those houses, and god knows what a cannabises farm is?
You can call me picky, but I just think that representatives of a trade such as ours, should be able to string coherent sentences together??
There are standards.
Edit
That was it: "voltsticks to inducate magnetic force." Could you translate?
Advice needed on poor junction installation
harry olee,
DPG,
