H
harry olee
I discovered this whilst removing tiles in my daughters kitchen.
It disintegrated when i touched it with the sds drill
No enclosure just a backing plate rawl plugged to the wall and plastic terminal blocks behind.
As its unsafe and exposed I need to repair it as quickly as possible.
There isn't any cable slack to play with for use with a wago MF box..
I was going to use an wiska adaptable box with wagos but ideally a metal double socket box with a surface mounted plastic blank plate would look better when she has it re-tiled
Is it ok to use wagos in other enclosures even if they are accessible?
Is there a better alternative arrangement?
