Discuss Advice needed on running a 2.5mm cable in kitchen. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys,
I just needed some advice on running a 2.5mm cable.
As I'm still a trainee doing my college course, I thought I'd ask the experienced guys on how I can do this.
I have made the video on youtube to explain exactly where the cable needs running.
Here is the link.
Any advice is much appreciated
ZippyMo
Trainee Sparky
It looks like the ring has a fault after the kitchen, therefore, this looks like if you put the ring onto two radials the whole kitchen and prior back to the C.U. would be put onto a 20A radial.
That drill hole on the R.H.S. of the kitchen socket looks very near the line of the cable.
trunking along top of skirting board- move fridge, might be able to fish new cable behind the cupboard. then up, chase behind worktop, cut tile , chase in cable, repair tile. if the wall is dot& dab, might even be able to fish behind the board. ( and do something about that southern accent, i could hardly understand what you were saying. :p:p:p.)
Where does the third cable in the kitchen socket go to? as it could be an option to do as Tel has posted above but to take the cable to there making a ring and disconnecting the faulty cable.
Yes mate the grommets are definitely something I will add.
Like I mentioned in the video the house was wired around 30 years ago. Probably grommets were not even included in the regs at the time.
Where are the fridge freezer plugged into,is it possible there are points served behind them in between your 2 sockets?
This is a good point maybe that third cable at the double socket goes to the fridge/freezer socket. This is a thrown in at the deep end for a trainee in the real world of being an electrician.
I pulled the fridge freezer forward to see how much room I have and I did find an extra socket which is actually part of the other circuit containing the fused spur that I mentioned.
The 3rd cable in the kitchen socket runs down to a socket under the worktop which is a spur socket. The oven is plugged into this.
As I posted before it may be easier to ditch the faulty cable between the two double sockets and install a new one between the one right of the fridge and the oven. Have you not got a cooker circuit?
Reply to Advice needed on running a 2.5mm cable in kitchen. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
