I have read the above it confirms my stance but rather conflictly also confirms yours too.
I read it as if the case is just that carry on if it forms part of a combustion chamber or seal you need to be gas safe. (some of the new condensing boilers)
No wetpants installs the boiler and runs it up/commissions it off a plug top. Electrician goes in maybe that afternoon or sometimes a few days later an wires boiler/controls. wet pants doesn't return to site.
which manufacturer of boiler and your talking about combi arnt you, as you wouldnt be able to use the system if port valves arnt open etc
and most these days account for your sparkys not having to open up to get at the elecs have a look at worcester cdi compact/si
but how do you know what type of case it is, thats where the gas safe engy comes in
Worcester, ideals, vokera, baxi, valiant and no not just combi boilers, systems and heat only boilers also. valves can be manually opened if required. I've witnessed it myself many times when I subbed off of Eaga.......electricians went in after plumber and plumber never returns.
well thats breaking the rules, and if your friends plumbers etc are leaving port valves open that could kill someone or seriously hurt them
Sounds like the plumbers weren't qualified either. That or they'd met you before.
@Croppie you must be gutted you don't have a ban hammer here so you could swing it like you do over at the plumbers forum when some one doesn't agree with you? Every one might hang off your every word over there but they certainly wont here :).....chump
@Corbs it obviously only remains on a plug top for the time it takes to commission the boiler/run it up. Its not left on it for the customer to freely use its removed once commissioning has taken place. Combi boilers might get left on a plug top though.
thats not good leaving your customers without heating or hot water for a day or two
You really are a special kind of idiot aren't you. You've been allowed to live over there so far despite the attitude you portrayed.
