There is still great confusion all around here and IET has yet 'to my knowledge' to give a definitive response to the questions posed to them about the confusion of this regulation 421.1.201
Here lies the problem - The consumer unit or similar switchgear has to comply to BS EN 61439-3 with basically is a set of test like an hot touch, self extinguishing etc...
As worded by the regs -
Within domestic (household) premises, consumer units and similar switchgear assemblies shall comply with BS EN 61439-3 AND SHALL;
(i) have their enclosure manufactured fromnon combustible material, OR
(ii) be enclosed in a cabinet or enclosure constructed of non-combustible material and complying with reg 132.12.
NOTE 1: Ferrous metal , e.g. steel, is deemed to be an example of a non-conbustible material
NOTE 2: (Just mentions implementation date jan 2016)
Now the problem here is the regulations states it has to comply to both the BS61439-3 and be non combustible if you do not house it as to point (ii) but there's no documented definitive definition of a non-combustaible material but they do give an example so this is not saying it has to be steel.
My next point is everything is conbustible given high enough temperatures and the conditions to burn so we need to know the exact requirements to be given a non combustible rating are.... all the manfacturers have to comply to is the BS 61439-3 and that allows them to meet the first part if the regulation but who is going to define the parameters of the word non combustible, yes steel is an example but as this is the only example they give we are stuck with the example as we have no other information to go on.
Try BS EN 60695-2-10,11&12 and BS EN 13943 for that definition DW.
It's quite clear I think![]()
You're right, it's a joke
Until you drop it!just about to start up in production of CUs made entirely from glass.
1. glass is non-combustible.
2. end user will be able to see the poor terminations made by the Electrical Trainee's and avert a fire by calling in a competent electrician to fix it before a fire breaks out.
SORTED.
can't read that d!
Too small even on the laptop screen, don't have a desktop machine to make it bigger on at the moment!
Had a conversation at wholesalers today. They are stopping providing the old CU's. New wylex m/clad 10w HI £80 without breakers.
Wylex 40mm gland for tails £10, others available for £5. Some sort of sealed unit for rear incorporating glands £30....so we're talking something like £160 for a complete unit. Double the cost.
Looks like there's not going to be much choice. Short and curlies, eh? Ridiculous!!
are you sure www.youtube.com/watch?v=12OSBJwogFcUntil you drop it!
Just fitted a metal wylex split board for less than £120 in parts - 8 x mcb and a 40mm stuffing gland, you're getting ripped if its £160 the wholesaler was even taking about a fully loaded soon for less than £100 so not sure where your getting yours from.
Borosilicate could be the answer!The issue with glass of most kinds is it stresses easily with heat so focus the heat in one spot it usually shatters .... not enough info in the link but totally respect your response lol
I believe the issues with 'exploding' pyrex were down to using inferior tempered soda-lime glass instead of borosilicate which incidentally most laboratory glassware is made from.Yes we have oven ready Pyrex glass ... but you missed my key point, if you heat up only one spot of glass the stresses between the hot and cold areas can cause it to shatter, fracture, crack etc ... oven glassware is heated up more or less evenly so little issue but car windscreen are a good example for shattering or cracking when you poor boiling water on it to melt the ice. The link gave limited info on properties of the glass so may not be suitable or even cost effective.
Just look up exploding pyrex dishes etc ..consumers ignoring usage warning and putting a hot dish under a cold running tap is one way to achieve this.
Glass is an insulator so is prone to temp' differential stress where as metal is a good heat conductor and doesn't shatter with high temperature gradiants across its surface.
I wasn't being serious as I'm sure Tel wasn't when he suggested glass being used for cu's but the more I think about it the more I'm 'warming' to the idea.
true, did you look at part2 its very interestingYes we have oven ready Pyrex glass ... but you missed my key point, if you heat up only one spot of glass the stresses between the hot and cold areas can cause it to shatter, fracture, crack etc ... oven glassware is heated up more or less evenly so little issue but car windscreen are a good example for shattering or cracking when you poor boiling water on it to melt the ice. The link gave limited info on properties of the glass so may not be suitable or even cost effective.
surely the root of the problem is not that the consumer units are combustible or not, but why they catch fire!!!!! instead of making all domestic consumer units non-combustible so that they just contain any fire that may/may not be occurring they seem not to have addressed the cause of the problem which is likely to be poor terminations or overload situations - these are still going to be there, just hidden away.
would it not be better to try and sort out the cause through teaching people how to terminate cables and not overload circuits, more inspections on domestic properties etc etc. But no lets just ignore the causes and opt for an easy way out.
cant see that this new regulation will solve anything.
Main thing that bothers me about all this, is the fact that a bad installer will still do a bad job,
There'll still be CU fires and possibly electrocutions will rise, something which was not really a problem before with insulated Cu's so by trying to solve one issue another has arisen.
The only good thing that may come from the above scenario happening is that a proper licensing scheme may be eventually introduced for electricians, with stringent criteria !
Sadly a few lives need to be lost before common sense comes into play!
