Discuss Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Pity!
As I said above. You cannot leave live cables in the wall and just plaster over them, unless they are at least 50mm from the surface.
So you have two obvious options
1. Rewire the socket so there are no cables in the wall. This may be tough as the cables come from two directions, but there may be a service duct in a corner, or other routes that the cables could take. You'll obviously need to find a location for a junction, or two.
2. Connect the conductors together, in the existing back box, using some insulated terminal block, or Wago-type connector.
Then put a blank plate over the back box, but on top of your new plasterboard so it can be seen.
Sounds like it's an upstairs RFC feeding sockets below and a single T&E drop.
Not a 70's built house by any chance?
Pity!
Yes, that's the route I'll take terminal block with a wall plate.
Use Wago or similar, not those horrible choc block things...
This may look expensive on the face of it however they will cover most options in your house and are rated for up to 32 amps: https://www.NoLinkingToThis/p/wago-lever-connector-set-32a-85-pieces/2305r
Erm...what sauce would you like on your hat, MDJ?
I installed a new loo and got a Building Warrant and Completion Certificate for that.
The lady from BC who inspected it was in the house less than 1 minute, said "Nice shower!" and left!
Well there is always one t!t
'Thank you for your quick reply. The socket is too close to zone 1. Behind the socket three cables converge, bearing in mind that I am replacing the plasterboard in that area what is the best method of connect the cables together?'
Either use the existing back box, suitable connectors and a front plate or a suitable maintenance free junction box. Any further information, would be a step by step guide, which is against forum rules.
I'd consider employing a competent electrician. Such work could be notifiable to local building control.
You can build a cupboard around the socket
Thanks for the suggestion, I've ordered a box they're just what I need.
I would suggest you get an Electrician in ;)
Some places find that sockets in the bathroom are the way to go...
Obviously the low level socket is nearly 15cm from the edge of the wash basin, ideal for my straighteners, and the higher level hairdryer and shaver socket make sense too as they are miles away from the basin...
and while I am talking Spanish electrics,
as a total amateur, what are the 3 chaps at the right? I am guessing they are to do with the card-switch system, so when you put your card in the slot so you can use the lights etc these activate the circuits for them and the sockets and aircon? Clearly that wee slotty thing can't carry the load on its own. Or am I talking rubbish...
Bleedin' 'ell...….Johnny Depp talkin'?
Reply to Are mains sockets permitted in bathrooms? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
I have a socket in by bathroom vanity unit, .75m away from the edge of the bath. The vanity is completely enclosed with a sink on top and doors...
Had to remove a led strip from a bathroom today because it’s getting tiled, now the led strip that was there was low voltage but didn’t have...
