L
Lazlo
or have you begun to install metal re:amendment 3...
You big poofYep. Got my collar felt for having a laugh. Lesson learned. No more jokes. You get banned for jokes. So I will just slag everyone else off and then place them on my ignore list when I lose the argument. You don't get banned for that.
or fit a normal plastic CU as we/ve done for years. tighten all the connections properly, then put it down as a deviation ( non-compliant but no less safe than if it was) so up yors IET or whatever you'll be called this time next year.
If you fitted one in my house I would ask you to remove it or I would get someone to replace it with a plastic one and deduct the cost from your final bill Dave lolYes I do fit metal CU's, as I always have done since I was an apprentice. The only time I don't is TT installations.
You big poof
Exactly lolall depends where it's fitted. if it's in a cabinet or in the garage, who cares?
HAHA got yu :biggrin:No you wouldn't because being an electrician you would have done the job yourself. But if you did then I would be charging you for the full cost of replacing it as I would have your written acceptance of my quote detailing a metal clad CU would be fitted.
By "poof" I take it you mean the foot stool in your lounge and not the derogatory term for homosexual men as that would be a clear breach of forum rules and make me weep. Lol
The new regulation doesn't take effect until January 2016 and as yet it's not confirmed that metal is the only way to comply.
BEAMA says that the primary root-cause of fires in consumer units has been clearly identified as resulting from loose connections
so when they gonna start putting push fit connections in CU's then, like you get in sooo many light fittings these days!
BEAMA says that the primary root-cause of fires in consumer units has been clearly identified as resulting from loose connections and this new regulation is intended to provide a level of enhanced fire risk protection in this event.
And the Regulation also states that it may be contained within a non-combustible enclosure instead of using a non-combustible dis. board.
Is there anything in the BYB about how big the non-combustiable enclosure has to be or what it has to protect the fire from?
Yes I am expecting some comments about how if I wish to know I should buy a copy, but just had a idea that may get round this new reg that I am willing to share with you all.
What about Bakelite? Oh! perhaps not, we've had that before.I fit plastic CU's but I cover them in Bakofoil. Like a metal CU then innit. Except they still catch fire. At least they cook through evenly now though.
I strongly suspect manufacturers will come up with a suitable plastic box before 2016.
Misleading information – a redress by BEAMA
However, BEAMA feels that there has been much misinformation about this likely requirement, so is setting the record straight.
Commented BEAMA’s Deputy Director, Installation Sector, Keith Smith: ”Much has already been written, some of it highly speculatively and potentially misleading, about the forthcoming Regulation 421.1.201 that is intended to improve fire safety in domestic premises.
“BEAMA, on behalf of the leading manufacturers of consumer units, has published a Technical Bulletin entitled ‘Enhanced Fire Safety from Consumer Units’ to give industry guidance and bring some clarity to the intended application of Regulation 421.1.201
“The content of this Technical Bulletin is fully supported and endorsed by leading industry bodies, including ECA, Electrical Safety First, IET and SELECT.
“A further point for clarification is that plastic enclosures manufactured from 960 degree glow-wire rated material would not be classified as ‘non-combustible’ in the context of this regulation.
I personally find this new regulation irritating but I cannot see how any one will get away with fitting plastic consumer units in a domestic setting when this regulation comes in to force at the start of 2016 if you are part of a CPS.
Its all very well for that muppet to say what he likes BUT they, and I include all those organisations listed, have ALL colaborated to introduce what can only be described as a FARCE of a regulation.
And to cap it off WE, the Professional Sparks will have to justify this to OUR clients - and yes its more cost - and the big sheds will still sell plastic CU's to ANYONE!!!!!!!!!!!!!!!!!!!!!
100% mate, it is a complete FARCE IMO. I was just pointing out what BEAMA are clarifying on the use of 960 degree glow-wire rated material and that it would not be classified as ‘non-combustible’ in the context of the new regulation.
I've sent Keith an email via the contact address at Beama - be interesting to see if he responds!
We are installing consumer units to BSEN 61439-3
Constructed of Self extinguishing ABS.
Amendment 3 refers to metal as an EXAMPLE of non combustible material not as the ONLY non combustible material.
So until they clearly define exactly what non combustible material is, and what BSEN number we have to follow.
This thread and many others will continue to propagate opinions, speculation, and continued confusion.
The whole scenario is a complete disgrace to the industry, and to those who have to work and comply within it.
There seems to be a large number against this new regulation..
Does anybody have any figures as to the number of objections prior to its introduction?
Pethaps it should have never been introduced and also why don't we start a petition to get it scrapped
Cobblers is my first thought. Virtually all the businesses mentioned in the text above have something to GAIN financially by agreeing to this change.
