sparkyork
As above drilling from floor above I thought I was going through a 3x2 bracer but turned out it was the top chord of a tji joist! In all my years and knowing the golden rule ! Well I'd say id describe myself as devestated!
If any seasoned member can say they have never screwed up then I wouldn't believe them, stand up dust down, evaluate, sort it out and move on..... never linger on screw up, it will send you mad and question your sanity.
Cheers bud, your right it's just frustrating when you know not to drill them!
I've been researching repair methods and it seems that ply glued and screwed to the sides of the trusses over a certain length may be the remedy, site manager will be finding out tomorrow.
Like most similar issues ... it just need a long enough brace to take the stress off the damaged area. I wouldn't loose any sleep on it but yes its frustrating.
Hi bud,yep,we have all been there....
If it is of a Glu lam type,and the person in charge,forces an answer from the manufacturer,it will be a "no".
The only deviation from repairs/alteration of top and bottom chords,in my experience,is to allow a type of "birdsmouth" for pitched bearing on wall plates....and they are very prescriptive,on achieving this...
There will be other ways round your problem,some constructional,some political.
Fair-play to you for your honesty (accepting your drilling didn't send anything south...)
Hope you solve it simply.:flowers:
I feel for you. Hope you can get away with a minor repair, if not get an insurance claim in and just consider the excess you'll have to pay as being school fees. Don't stress, we've all been there, let us know how it goes.
Its not making the mistake, It's how you correct it thats important and im sure you will do that in a very professional manor
,fell through a ceiling once last day of a rewire repaired it even down to matching up the old poor mans artex remember that like course sand paper glued to the ceiling
lol weve all done it
What's this thing you drilled through? Can you provide a picture.
images
Is it a joist but with chipboard stuff in the middle? I have to say, a 20mm hole is not going to cause a problem, I wouldn't ha e batted an eyelid.
Yes it is a problem, they are engineered timber joists built to very specific tolerances. The manufacturers warranty will be null and void unless an approved repair is carried out for a start. These joists can only have a certain number of holes in the osb web and nothing in the gluelam flanges/chords. This is why they have pre-made holes in them, though most manufacturers will allow you to drill a certain number of holes in certain places
i'm lucky enough not to have worked on any of these modern egg-box houses. my worst was years ago, drilling a c/h pipe.
Thankfully I rarely do domestic unless it is something I just can't get out of. But Like Tel whatever happened to proper wooden joists?
Sparkyork I wouldn't beat your self up too bad about this, if it were me I would be drilling holes till the cows came home, and most likely thinking to myself, that wasn't to shabby nice easy drill that!!!
They are a yankee idea,where weight and cheapness/speed of construction are cited as benefits. They were also sold as being "squeek-free" ....whatever that scientific badge means...
I have straightened and re-used many solid timber joist constructs,after long periods of dereliction or flood damage. Some of these glu-lam beams,only need a weekend period of a localised water leak...and they're done...
A good pal of mine,used a pile of salvaged Glu-lams,to purlin out his cattle shed,and the damp turned them in to a kind of architectural art installation...
Strange how these days,your floors,beams,work-tops and all your cupboards,are made from the all the bits,the apprentice used to sweep up :wink5:
I guess they're just a sign of the times. Houses used to be built to last and also they'd maybe get the odd extension tagged onto them but they'd usually remain as-built for their entire life. Nowadays people want to reconfigure and rebuild their house every few years according to the latest fashions so I suppose the permanent building methods of old would just be a waste of time and good materials if they're getting replaced regularly.
Thanks chaps, the site manager said if I can hide it by plugging it then that'll do! In the big picture it's never likely to be a problem but could of been a different ending! Should be happy days fingers crossed.
Noticed today one of the tv cable blokes ran a coax between the tji joists and stud work tops which looked iffy to me but he said there's ten mill gap and is in zone!
i think your blowing this way out of proportion a 20-25mm hole in a flange wont cause the whole structure to become drastically weak and dangerous. An elliptical hole through a flange from above causes very little structural damage, if you had drilled from below across the flange it would have been more damaging result. I have drilled 4'' and 5'' hole through these joists and as long as you space them apart you wont have any issues. i have glanced and drilled a few flanges in my time because thats life and s**t happens its mostly due to other participating factors like positioning of stud work and accessories. Dont loose sleep 1 hole in the wrong place wont make the property fall down besides the tolerances of the joist are higher than what the manufacturers permit anyway. As for trad joist i hate them as they are a pain to drill and make wiring a nightmare.
if your drill struggles you need a new drill
im on about the specified drill zones and the fact their 15cm thick!
What joists are they? 6" is thicker than a normal joist
I did an extension a few years ago that was built with a proper oak frame. Those oak beams at around 10" thick were an absolute buggerance to drill.
Well the OP has cheered me up this Monday morning. I drilled out for recessed LEDs on Friday and did a whole row in the wrong place. Customer now has 4 more lights than they expected!
I hit a gas pipe once, that was immediately behind the CU I was changing and 1 inch below the old one. New CU was bigger and I put a screw through the pipe (hidden by insulation)! As others have said, no dramas, just move on!
These special softwood joists made from the same stuff cls is. We had a contract working on some fancy 3million pound homes for a national builder and the joists we over-specified it was an absolute pain as auger bits were all we could use and the space between joists were very tight!.
Op I know this feeling too well !
I once drilled thru a joist from the side in the correct place and didn't check that it wasn't a double joist, I just got carried away slightly as you do when you're under pressure to get it done, and drilled thru the wooden joist holding up the staircase,
I realised what I'd done and immediately told the site manager who after a lot of erring and mumbled swearing said it's a long shot but I'll ring the structural engineer for his opinion. .......
I was very lucky as it was only a 20mm hole and he said 15 mm further to the right and we'd have had to pay for it to be replaced!
2 weeks later a plumber went through a joist twice with a bigger hole in a worse place on the same joist in another house ....
He was a favourite of the contracts manager as they played golf occasionally and said wet foot was semi pro, all that was said was
"oh well these things happen "
No charges incurred or implied! !
Proven case of "not what you know but who "working to his favour!!!
Taught me a good lesson though!
Email
Time zone
Last seen
Bad day today :-( drilled a 20mm hole straight through top chord of a tji joist
sparkyork,
edexlab,
