derekwoolley
I’m switching out timer light switches for normal light switches in my bathroom. One went to a light and fan and the second went to another light and fan. In the wiring box I have two sets of wires coming in. One set has green ground, white neutral, black hot, and red hot. The other has green ground, white neutral and black hot. I can get one switch to work normally but the other the ways I’ve wired it will either not work at all or be on but the switch doesn’t turn it on or off. How do I wire these correctly?
