M
mikex79
hi i just want to clarify two thing as i cannot find it in the regs
1. If i have a endant in a bathroom but the circuit is an rcd protected, doe the pendant needs to be replaced with a propriate IP luminaire to meet the 17th edition standards, please provide a reg number if possible
2. does the light circuit within a domestic installation consumers unit need to be on a separate rcd so in case that s the general installation rcd trip there still will be the light on in the house or can they be on the same rcd. if to provide with 2 separate rcds is recomanded is it just e recomendation or must. any reg numbers?
thanks
thanks
- there is no reg that says a lighting circuit must have its own rcd / rcbo. Bathroom lighting that is installed now must be rcd protected but that rcd can be protecting a number of circuits. The reason why you might want to have it on its own rcd/rcbo is to prevent the nuisance of one fault shutting down lots of other circuits.
